Power FC vs. Nistune
  • Power FC vs. Nistune
    Ich denke mal das es sehr interessant ist darüber zu diskutieren welche Vor- und Nachteile es gibt.
    Nistune:
    Preis: ~120€ (mit Software 260€)
    NIStune is a real-time tuning suite designed especially for Nissans which provides the ability to:
    - Retune factory Nissan Engine Control Units (ECU)
    - Monitor gauges and map tracing on your ECU
    - Data log from your ECU using consult, wideband and auxiliary inputs
    - Perform playback using graphs, gauges and map tracing
    It provides:
    - Connectivity for up to two emulators simultaneously (Pocket Romulator and Moates Ostrich)
    - Loads and Saves files in regular and odd/even formats for chip burning (EPROM/FLASH)
    - Support for up to two simultaneous wideband units (various
    commercial units supported)
    - Communication to our specially developed NIStune Real-time boards to perform real-time tuning
    Features:
    - Real time tuning, map tracing, logging and playback
    - Consult display capabilities with real time diagnostic information in a
    separate window
    - Full Log Recording and playback is available for all consult variants.
    - Dual channel Wide Band support
    - Wideband can also be recorded inline with consult data and played back.
    - Edit five ROM images simulatenously, with comparison capabilities
    Map and table copy feature
    - Intelligent display tables decoded for easy modification
    - Completely editable multi window grid, map/table views
    Knock cells highlightable, pinpoint map trace configurable for follow and trail functionality, cell marking available
    - Resize injectors and change AFM capabilities
    - Real time RAM monitoring system
    - AFR and auxillary input trace against RPM and load
    - Hardware and software installation guides and manuals provided
    Vorteile:
    - niedriger Preis
    - Diagnose über Conzult noch möglich
    - schnelles aufspielen anderer Kennfelder möglich
    - noch in der Entwicklung und immer wieder Verbesserungen
    - Basismap vorinstalliert
    Nachteile:
    - noch nicht für R33 und R34 GT-R erhältlich
    - Laptop wird benötigt
    - Mapauflösung 16x16 Kennfelder
    - Board muß in die ECU eingebaut werden
    Power FC:
    Preis: 750-850€ (mit Software Datalogit 1050-1150€)
    The Power FC proudly stands as A'PEXi's answer to the constraints and limitations associated with most piggy-back style fuel controllers. The Power FC is a complete, stand alone, total engine management system capable of handling virtually anything thrown in its path. From multiple point fuel and ignition control to VTEC engagement (Honda applications) and boost settings, the Power FC is capable of accommodating even the most demanding performance enthusiasts.
    Currently available exclusively through Power Excel Shops the Power FC replaces the factory ECU and controls all vital engine parameters (Off road use only, no OBD-II). Installation is as easy as replacing the factory ECU. (Some minor rewiring is required on select vehicles). The factory engine harness does not need to be replaced and all critical accessories such as air conditioning continue to function. By using the optional FC COMMANDER, the user can adjust and modify a wide range of settings. Since there is no need to upgrade ROM chips or modify ECU's, the factory ECU can be kept by the original user.
    The Power FC operates off of three Main Menus. These menus are: Monitor, Setting, and ETC.
    In Monitor Mode, the Commander can display up to 10 parameters of data in real time. Monitor Mode can display:
    Engine RPM
    Ignition Timing
    Vehicle Speed
    Air Flow Voltage (Pressure Sensor Voltage)
    Injector Duty Cycle
    Boost
    Knocking Level
    Battery Voltage
    Intake Air Temp
    Water Temp
    In addition, there are 4 display patterns allowing 1-8 parameters to be shown on screen simultaneously. The data displays in numerical real time values with the option of a real time 10 second graph display. Peak Hold values and Display Hold functions only require the touch of a button. The Map Trace Mode allows Ghost Map Tracing of the Fuel Correction and Ignition Timing maps. This allows the user to visually see what point of the map is being used in real time. The Ghost Map Trace function leaves markers on the used portions of the map for easy reference.
    Setting Mode allows full access to the 20x20 ignition timing and fuel correction maps. The user can adjust any portion of this map in 5x5 sections. Air flow correction values can be entered for vehicles upgrading air flow meters. Injector pulse correction menu is used when upgrading injectors. The Acceleration Enrichment Correction function improves response under hard and sudden acceleration. The Cranking Fuel Injection menu corrects the amount of fuel delivered when the engine is being cranked, or when the water temperature is cold. A separate Water Temp menu allows fuel correction according to water temperature. The RPM menu allows rev limiter settings and idle RPM levels. Access menus also vary according to specific applications. Rotary engine Power FC's accommodate leading and trailing ignition maps. Honda engines Power FC's allow for VTEC control. Complete boost control is possible by using the optional Boost Control Kit. Changing data is easy: just access the desired point on the map or data, and push the FC COMMANDER keys in the appropriate direction.
    The ETC Menu contains utility parameters such as: version information, LCD screen brightness, and initialization of all data. In addition, the ETC Mode allows the user to monitor all factory sensors through one screen. This screen can tell the user if any sensor is in use or malfunctioning.
    The Power FC also comes preprogrammed with a base map. (Currently with Japan Domestic Market Vehicle Maps, minor initial tuning may be required. Please contact your authorized Power Excel shop for more information.) This makes the initial tuning process much quicker. As with all other fuel controllers, the POWER FC should be tuned on a dynomometer by a trained professional. A high grade air/ fuel ratio monitor is also recommended during tuning to ensure best results.
    FC COMMANDER (part of Power FC)
    The FC COMMANDER is a hand held controller designed to allow access to the vital parameters within the Power FC. The unit allows a wide range of data modification through its large back lit LCD display. The unit has been designed so that one finger can control a wide array of data. Once connected, the A'PEXi logo will appear in the screen taking the user to the Main Menu. From here, the user can access the three Main Menus (Monitor, Setting, Etc.) The FC COMMANDER "communicates" with the Power FC control unit thereby creating one of the first interactive user friendly fuel management systems.
    BOOST CONTROL KIT (part of Power FC)
    The Boost Control Kit is an optional kit designed to control boost through the Power FC. Simple connection to the Power FC allows the user to access a full self-learning boost controller. The Power FC allows up to 4 different boost presets for any stage of driving. The high grade solenoid valve is the same one used in our Super AVC-R boost controller. As with the S-AVCR, the Boost control kit allows increased boost response and boost stability at high RPM's.
    Vorteile:
    - Werte können per Hand schnell korigiert werden
    - Mapauflösung 20x20 Kennfelder
    - verschiedene Werte können mit dem Handcommander angezeigt werden
    - plug & play
    Nachteile:
    - hoher Preis
    - keine Diagnose über Conzult mehr möglich
    - Entwicklung abgeschlossen keine Neuerungen
    Wer kann noch Vor und Nachteile nennen?
      Empfinde ich nicht als nachteil, beim PFC brauchst ja auch den Commander.
      Da ist mit aber ein Laptop lieber ;)
        Für mich auch nicht hab ja Car-PC :P
        Geht aber drum während der Fahrt mal schnell was zu ändern ohne das man einen Laptop dabei haben muß.
          Kann man beim Power FC kein Laptop anschließen? Dachte da geht sowohl als auch.
          Mal ein bisschen Off Topic: Kann mir einer sagen wo denn im Normalfall das Steuergerät verbaut wird. Weil meiner hat laut Verkäufer ein Power FC verbaut, aber ich habe nicht das PFC Handteil im Innenraum, sondern einen Controller von Blitz.
          Gruß, Daniel
            Links unten im Fußraum (beifahrerseite) , hinter der Seitenerkleidung.
              was für einen unterschied macht die Kennfeld grösse?
              Gruss
                Mehr laststützpunke, dazwischen wird interpoliert.
                Also je mehr Stützpunkte um so feiner läst sich der Motor abstimmen.
                Hier als Beispiel ein bild von meiner EMS Software:
                25x12
                  Beim PFC ist bei mir nen Datalogit angeschlossen und über dieses kann man dann einen LapTop zum progr. anschließen.....
                    achso ok,
                    Naja also ich würde wohl das kaufen das mehr bringt^^ und nicht nach Preis/Leistung suchen. Die ECU kann man ja immer wieder brauchen da nimmt man lieber was ordentliches.
                    Ok ausser der Preis ist horrend höher als ein etwa gleich gutes Exemplar.
                    Aber so jetzt ausm Ärmel wärs bei mir das APEXi.
                    Consult ist mir eigentlich egal
                    Edit: Bei meinem R34 mit PFC hab ich übrigens auch Datalogit kann also auch Laptop angehängt werden (da ich keinen Commander hab)
                    Gruss
                      Das Apexì ist schon TOP aber is nur doof das man keine Fehler auslesen kann ....
                        Ich bin ja vom Nistune überzeugt :]
                        Was kann das PFC was das Nistune nicht kann? Jetzt bin ich mal gespannt :P
                          hattest du nit gesagt, dass es das Nistune nicht für R33 und R34 gibt?
                          also is es doch quasi egal was das eine kann und das andere nicht... Für den großteil hier im Forum kommt somit nur das PFC in frage :(
                          No Risk, No Fun
                            Noch nicht ;) Wenn er Zeit hat macht er sich dran. Er hat alles dafür da um damit anzufangen.
                            Ich hoffe ja das es fertig ist bevor ich mit meinem Auto fertig bin.
                              ich setzt auch auf PFC
