Hi wie kann mann hochohmige duesen anstatt niedrigohmige duesen benutzen ?in verbindun mit einem power fc mfg yvo
Frage Einspitzduesen
Ja das geht, wenn man dem Text da unten glauben darf sollte man es sogar machen.
What ecu are you running? If its the Apexi PowerFc then the injectors need to be Top Feed High Impedence. Reason being the power fc doesnt have a tunable injector driver so u cant change the settings. Most other aftermarket ecu's do have adjustable injector drivers. Note - RB26 injectors are Top Feed Low Impedence, RB25 (non R34) injectors are Side Feed High Impedence.
