Bodywork
Type: 2+2 FHC
Number of doors: 2 - 4
Dimensions
Wheelbase: 2720 mm 107.08 in
Track front: 1486 mm 58.50 in
Track rear: 1490 mm 58.66 in
Length: 4675 mm 184.05 in
Width: 1780 mm 70.07 in
Ground clearance: 135 mm 5.31 in
Kerb weight: 1540 kg 3395.11 lb
Fuel capacity: 65 l 17.17 US gal
Engine
Code: RB26DETT
Manufacturer: Nissan
Type: S-6
DOHC
24 valves total
4 valves per cylinder
Bore x stroke: 86.00mm × 73.70mm
Bore / stroke ratio: 1.17
Displacement: 2569 cc 156.77 cu in
Compression: 8.50:1
Fuel system: EFi
Aspiration: Turbo
Intercooler: Y
Catalytic Converter: Y
Max. output: 279.8 PS (276.0 bhp) (205.8 kW)@6800 rpm
Max. torque: 368.0 Nm (271 lbft) (37.5 kgm)@4400 rpm
Coolant: Water
Specific output: 107.4 bhp/litre
Specific torque: 143.25 Nm/litre
Performance
Power to weight: 179.22 bhp/ton
Chasis
Engine location: Front
Engine alignment: Longitudinal
Steering: rack & pinion PAS
Turning circle: 11.40 m
Suspension front: I.MultiLi.CS.
Suspension rear: I.MultiLi.CS.
Wheels F/R: 9.0JJ x 17/9.0JJ x 17
Tyres front: 245/45 R 17
Tyres rear: 245/45 R 17
Brakes: VeDi/VeDi-S-ABS
Transmission: 5M
Drive: AWD
Top gear ratio: 0.75
Final drive ratio: 4.11
Type: 2+2 FHC
Dimensions
Engine
Code: RB26DETT
Type: S-6
DOHC
24 valves total
Compression: 8.50:1
Fuel system: EFi
Aspiration: Turbo
Intercooler: Y
Coolant: Water
Performance
Chasis
Transmission: 5M
Drive: AWD
