Bodywork
Type: 2+2 FHC
Number of doors: 2 - 4
Dimensions
Wheelbase: 2615 mm 102.95 in
Track front: 1460 mm 57.48 in
Track rear: 1460 mm 57.48 in
Length: 4530 mm 178.34 in
Width: 1695 mm 66.73 in
Ground clearance: 140 mm 5.51 in
Kerb weight: 1260 kg 2777.82 lb
Fuel capacity: 60 l 15.85 US gal
Engine
Code: RB20DET
Manufacturer: Nissan
Type: S-6
DOHC
24 valves total
4 valves per cylinder
Main bearings: 7
Bore x stroke: 78.00mm × 69.70mm
Bore / stroke ratio: 1.12
Displacement: 1998 cc 121.92 cu in
Compression: 8.50:1
Fuel system: EFi
Aspiration: Turbo
Intercooler: Y
Catalytic Converter: Y
Max. output: 214.9 PS (212.0 bhp) (158.1 kW)@6400 rpm
Max. torque: 265.0 Nm (195 lbft) (27 kgm)@3200 rpm
Coolant: Water
Specific output: 106.1 bhp/litre
Specific torque: 132.63 Nm/litre
Performance
Top speed: 230 km/h
Power to weight: 168.25 bhp/ton
Chasis
Engine location: Front
Engine alignment: Longitudinal
Steering: rack & pinion PAS 4WS
Turning circle: 10.40 m
Wheels F/R: 6J/6J
Tyres front: 205/60 HR 15
Tyres rear: 205/60 HR 15
Brakes: VeDi/VeDi-S
Transmission: 5M
Drive: RWD
Top gear ratio: 0.76
Final drive ratio: 4.36
Type: 2+2 FHC
Dimensions
Engine
Code: RB20DET
Type: S-6
DOHC
24 valves total
Main bearings: 7
Compression: 8.50:1
Fuel system: EFi
Aspiration: Turbo
Intercooler: Y
Coolant: Water
Performance
Top speed: 230 km/h
Chasis
Wheels F/R: 6J/6J
Brakes: VeDi/VeDi-S
Transmission: 5M
Drive: RWD
