Bestimmt ;)
Tranq's R34 & R33
Ah ja, hab ich mir fast gedacht; Warst Du zufrieden mit der Abwicklung?
Ich habe mal noch den Alex Imprtracing angefragt, der vertreibt die auch; Bin mal gespannt;
Vielen Dank und PS: einfach traumhaft Dein GTR!!!sigpic
Hi,
hatte keine zeit fuer neue Bilder. Hier ein paar alte und die Spec, wollte es schon frueher machen habe aber schlecht zeit dafur. Hoffe ich finde zeit ueber den Winter um was zu machen ;)
Spec zur zeit :
1995 BCNR33 / Skyline GTR V-spec.
27,500 miles.
EXTERIOR/body
clear front indicators
Nismo clear side repeaters
Nismo carbon style B-pillars
Nismo Carbon style spoiler end finishers
Deep front spoiler
Rear spoiler spats
INTERIOR
real carbon dash set, including ashtray cover and gear surround
Trust/GReddy 60mm warning gauges in glovebox consisting 2 x Exhaust temp (EGT), 1 x boost, 1 x oil temp.
Trust gearknob
White instruments(done here by the original supplier to Middlehurst)
Momo 360mm steering wheel, Nismo steering boss.
GReddy Profec B boost control - GReddy Profec remote switch.
Tein EDFC control unit in centre console box
SUSPENSION;
Tein 'Flex' coil over system with 'edfc' motorised adjusters.
Cusco adjustable front arms
Camber adjustable rear suspension arms
BRAKES
Front ; Alcon 6-piston front caliper set / 350mm discs/separate bells, Pagid pads,
Rear ; Alcon 4-piston caliper set, 280mm discs.separate handbrake bells, Pagid pads.
WHEELS
Nismo 10x18 'LMGT1' all round with Toyo275/35x18 tyres
EXHAUST
Mines super outlet 'pro' stailess exhaust outlets
Trust downpipes
stainless de-cat
Trust BL TiR full Titanium cat back exhaust
TRANSMISSION
OS Giken type A close ratio gear set
OS Giken high strength input shaft
OS Giken triple plate clutch
FUEL SYSTEM
Nismo in tank fuel pump
GReddy 11.0mm fuel rail and braided hoses
Nismo adjustable regulator
HKS 1000cc injector set
MANAGEMENT
HKS F-conV Pro
ENGINE/intake/ancillaries
Trust 3-row Rspl Intercooler,GReddy polished intercooler hard pipe kit
GReddy 16-row thermo oil cooler kit with remote filter mount
#12 braided lines
GReddy high capacity aluminium radiator
GReddy GTR blow off valve kit
ARC oil catch tank
GReddy rad cap
GReddy oil cap to engine and catch tank
GReddy strut brace
'GTR' stainless fuse box cover
GReddy radiator air diversion plate
GReddy racing suction pipe set with induction kit
HKS MAF delete kit
ATi Racing crank/harmonic damper
Split Fire coil packs
GReddy iridium tune -8 spark plugs,
Mines camshaft baffle set
Trust enlarged oil pan (sump kit)
Trust enlarged capacity front diff cover
Trust/GReddy T517z/8cm twin turbos mounted on massaged stock manifolds
Engine block bored +0.5mm (ie 87), GReddy forged Piston set(later style with 1mm compression rings)
GReddy H section connecting rod set
Nismo oil pump
GReddy crankshaft main stud set
GReddy cylinder head stud kit
stock Nissan crank on stock journal diameters,full dynamic balance to reciprocating assembly
Tomei engine block oil restrictor
Nismo connecting rod bearing set
Nissan crank bearing set
GReddy 264x10.0mm intake camshaft
GReddy 272x9.1mm exhaust camshaft
GReddy valve springs
Tomei valve guides
GReddy adjustable cam sprockets in/ex
GReddy high strength cambelt
GReddy clear front cam cover,
GReddy valve spring set,
Light head work /3 angle valve seats
GReddy 1.4mm steel head gasket
GReddy steel intake and throttle gaskets
Wirklich gelungen dein Wagen.
So stell ich mir ein Sky vor.
Die TE37 wirken wirklich gut in der ET. Vorallem in weiss, da sieht man noch das Tiefbett. Bei Schwarz geht es recht schnell verloren :(
Ansonsten TOP Wagen! Schaut echt 1A aus!
Junge junge.... da kommt mir leicht der Neidbolzen.
Ich hoffe, du hältst zumindest den R34 ne ganze Weile an dir. Wäre schade grade den zum Verkauf stehen zu sehen.
