Hallo,
war am anfang ein Hobby, wurde im letzten Jahr, mehr ....
Nissan Skyline BNR 34 V-spec UK No.35 – 2001, 27k miles, daily driver
Engine
HKS Intercooler Pipe Kit
HKS Intercooler fit
HKS Intercooler BNR34
HKS Sports DeCat Pipe
HKS Hyper & Race Cat.
HKS Hyper Muffler exhaust system
HKS racing plugs BNR34
Tomei Cams
Exedy twin – plate Clutch Kit
Management
Greddy Profec B spec 2
Greddy E- manage Ultimate ECU
Greddy BNR34 E-manage harness
Suspension
Tein Super Street suspension kit with Top mounts
Cusco Front and Rear top links
Nismo LM GT3 Alloys 9x18 with Toyo 265/35/18 T1R
Volk TE37 10.5x 19 with Michelin SP2 295/30/19
1995 BCNR33 / Skyline GTR V-spec. 24k miles, time attack project
EXTERIOR/body
Nismo clear front indicators
Nismo clear side repeaters
Nismocarbon style B-pillars
Nismo Carbon style spoiler endcaps
Nismo rear spats
INTERIOR
real carbon dash set
Trust/GReddy60mm ,2 x Exhaust temp (EGT), 1 xboost, 1 x oil temp.
Trust gearknob.
White instruments(done here by theoriginal supplier to Middlehurst)
Momo 360mm steering wheel,
Nismo steering boss
GReddy Profec B boostcontrol
GReddy Profec remote switch
Tein EDFC control unit in centre console box
Alpine cd/radio head unit
SUSPENSION
Tein 'Flex' coil over system with 'edfc' motorised adjusters.
BRAKES
Front ; Alcon 6-piston front caliper set / 350mm discs/separate bells, Pagid
pads,
Rear ; Alcon 4-piston caliper set, 280mm discs.separate handbrakebells, Pagid pads. (Brakes installed less than 5000 miles ago)
WHEELS
Nismo 10x18 'LMGT1' all round with Toyo 275/35x18 tyres
EXHAUST
Mines super outlet 'pro' stainless exhaust outlets
Trust downpipes
stainless de-cat
Trust BL TiR full Titanium cat back exhaust (exhaust fitted 2000 miles ago)
TRANSMISSION
OS Giken type A close ratio gear set
OS Giken high strength input shaft
OS Giken triple plate clutch (withflywheel)
FUEL SYSTEM
Nismo in tank fuel pump
GReddy 11.0mm fuel rail and braided hoses,
Nismo adjustable regulator
HKS 1000cc injector set
MANAGEMENT
Apexi Power FC
ENGINE
Trust 3-row Rspl Intercooler
GReddy polished intercooler hard pipe kit
GReddy 16-row thermo oil cooler kit with remote filter mount and #12 braided lines
GReddy high capacity aluminium radiator
GReddy GTR blow off valve kit
ARC oil catch tank
GReddy rad cap
GReddy oil cap to engine and catch tank
GReddy strut brace
'GTR' stainless fuse box cover
GReddy radiator air diversion plate
GReddy racing suction pipe set with induction kit
Nismo airflow meters
ATi Racing crank/harmonic damper
Split Fire coil packs,GReddy iridium tune -8 spark plugs
Mines camshaft baffle set
Trust enlarged oilpan (sump kit)
Trust enlarged capacity front diff cover
Trust/GReddy T517z/8cm twin turbos mounted on massaged stock manifolds Engine block
bored +0.5mm (ie 87)
GReddy forged Piston set(later style with 1mm compression rings)
GReddy H section connecting rod set
Nismo oil pump
GReddy crankshaft main stud set
GReddy cylinder head stud kit
stock Nissan crank on stock journal diameters
full dynamic balance to reciprocating assembly
Tomei engine block oil restrictor
Nismo connecting rod bearing set
Nissan crank bearing set
GReddy 264x10.0mm intake camshaft
GReddy 272x9.1mm exhaust camshaft
GReddy valve springs
Tomei valve guides
GReddy adjustable cam sprockets in/ex
GReddy high strength cambelt
GReddy clear front cam cover
Light head work /3 angle valve seats
GReddy 1.4mm steel head gasket
GReddy steel intake and throttle gaskets
R34 GTT Skyline, drift project
Front pipe
DeCat
Kakimoto Racing exhaust system
HKS Front mount intercooler
Apex'i Air Filter kit
Nismo Rad cap
Nismo Gauges
Apex'i Turbo Timer
Tein Super Drift coilovers
HiCass delete kit
Gizzmo boost controler
Apexi Power FC
Driftworks R34 GTT Suspension Arm Kit
Engine
HKS Intercooler fit
Tomei Cams
Management
Suspension
EXTERIOR/body
Nismo rear spats
INTERIOR
Trust gearknob.
Nismo steering boss
SUSPENSION
BRAKES
pads,
WHEELS
EXHAUST
Trust downpipes
stainless de-cat
TRANSMISSION
FUEL SYSTEM
MANAGEMENT
Apexi Power FC
ENGINE
ARC oil catch tank
GReddy rad cap
GReddy strut brace
Nismo oil pump
Tomei valve guides
Front pipe
DeCat
Nismo Rad cap
Nismo Gauges
Apex'i Turbo Timer
HiCass delete kit
Apexi Power FC
