We have been a aproved Link dealer and installer for a long time now and would like to show people their products.
The Link ECU is a very versatlile ECU that can be programmed to do all functions and settings you will ever need.
The large power from the Link is in the large selection of functions that you have in the ecu, the good qulity of the software and the options to take a Plug-In version of this ecu.
Here are some of the most important features of the link ecu:
- 6d mapping for fuel and ignition, ecu can work with TPS, MAF and MAP sensor. 6d mapping is also used for vehicles that run E85 and normal fuel. We are the only wordwide company to have made a full boost/fuel/ignition 6d mapping for different fuels
- boost control (RPM/TPS/... dependant, multiple boost settings, open and closed loop control)
- traction control
- launch control
- pre programmed trigger settings for most vehicles
- ALS
- Diagnostic mode, check every injector, ignition or sensor
- ECU datalogging (internal ecu dataloging without laptop or software)
- Lots more functions :D
We always keep the Link ecu for the RB25 and RB26 engine's in stock and can supply all other type Link ecu in a very short time.
Please contact us for more info about the Link products.
Mail: info@sky-engineering.com
Phone: 0031-6-54673686
- traction control
- launch control
- ALS
