TEIN Racing Spec RA Coilovers
Top zustand selten ein top RA set zu bekommen neu ca 1800$
Passt auf Skylines
-BCNR33 GTR RB26dett
-BNR34 GTR RB26dett
-ER34 GTT RB25det
TEIN INFO BLATT
The type RA allows you control to 1/1000 sec,
and to 1 millimeter
The TEIN technology for the advanced driver
* Type RA TEIN suspension has adapted into its package, the specifications used in the rally field such as the World Rally Championship. TEIN has constructed a footwork for you which gives priority to function.
* A high grade specification which gives you an unsurpassed drive feel.
* Introduction of specifications used at competition levels.
* Adopted a single rod structure for better reception between driver and road surface.
* A linear damping effect which adapts to even the smallest road surface abnormality by adapting the single rod structure.
* Seamless tube using a drawing method. Processing technology which enables a high level of precision up to 1/100mm of the inner diameter. Inner surface precision up to 3.2S (inner surface bumps within +/- 1.6 micrometer)
* Use of ultra light and strong aluminum - A7050 which is also used in airplanes.
* A I.D.45 piston which is maximum for marketed cars' shock absorber.
* A different diameter multi-level valve structure which enables damping effect and specifications adjustment.
* The damping effect adjustment structure uses an evolved version of the special shaped needle valve which has already been proven in the HA/NA dampers.
Great working order
Coilovers Used until recently with no problems. Great working order as far as we could test them
Please note shipping costs its a heavy item 27kg
Price
699 EURO
inclusive versand 4-8 wochen
Passt auf Skylines
-BNR34 GTR RB26dett
-ER34 GTT RB25det
TEIN INFO BLATT
and to 1 millimeter
Great working order
Price
699 EURO
