hi,
i'm Jo from belgium.
sorry that i write in english, but german is not so good, i can speak but not write
It started long time ago, always driving with tuned opel kadet GSI 16v with 240hp.
On one moment it wasn't enough anymore, so i whanted more, more power.
So i bought a nissan 200sx s14.
i drove that one for a while and tuned it to 364hp,
i go drifting with it on skylimitevents.be and free driving on zolder also.
but then i heard the sound of a 6 inline, and i whanted one, so i sold my S14 and bought myself a daily R32 GTST.
Why? i didn't whant a gtr of the 4wd, i always whant Rwd as my hobby is drift to.
so no i'm rebuilding the R32 like new while i'm driving it as daily car.
here are some pics of my old s14 :
and here are some pics of my R32 :
Spec list of my skyline now :
Engine :
Apexi filter
Kakimoto uitlaat 3" ceramic heatwrapped
AutoBahn88 decat 3" ceramic heatwrapped
3" downpipe rvs + bung welded for wide band
Mishimoto radiator + Mishimoto rad cap 1,3bar + blue alu rad mounts
Alu pulley on waterpump + powersteeringpump
Greddy RZ blow off
Greddy fusebox cover
Greddy radiator hard pipe
QSP tubing
Nismo Light flywheel (6,3kg vs 12,8kg stock)
Nismo Super Coppermix clutch kit
Nismo gearbox mount
N1 waterpump
Some custom polished parts
Nitto RB26 clear cover
RB26 cam backplate (painted silver)
HKS camwheels 1st gen
HKS timing belt
HKS purple Oilcap (rare)
HKS R-type fmic with custom welded piping (no fan trimming)
HKS RB 15W55 engine oil
HKS oil filter
Splitfire coilpacks
Splitfire earthing kit
Iritop 7 sparkplugs
Chromed coilpack bracket
RVS coilpack cover vented
Jap Aneos small battery
HKS coilcover decal oldschool
Ross Metal Jacket harmonic crank balancer
Single loop R34 powersteering pump, R33 powersteering bracket bracket.
R34 GTR/Stagea TM cooler installed as powersteering cooler
Tomei FPR type-S
Deathworks fuel pump
Braided Clutch line custom made (2parts)
suspension :
Nismo Front upper brackets
Nismo front upper camber arms
Advan AVS Model 6 rims pearl white, will be made black
Brembo front brakes van R33 GTR (painted blue)
Tomei hicas lock 2
Cusco front strutbar
Cusco rear strutbar
Cusco brake stopper
CST Zero-1 coilovers height and rebound adjustable
Whiteline subframe bushes black edition
Midori Seibi Drag rods (Hicas complete removed)
Nismo GT PRO 2way diff
R32 GTR axles + R34 GTR wheel bearings and handbrake pinion
HKS KSN001 underbody tunnel brace
Exterieur :
Veilside voorbumper
APR Performance Carbon mirrors
Nismo S-tune air valve caps
Nismo numberplate holder
Top Secret fuel cap
OEM winddeflectors
OEM door edge protection molding
GTR alu hood + N1 lip + GTR hood lock
R33 Chime style front grill
interieur :
Apexi AVC-R boost controller black edition
Hoshino Impul blue dashboard
Greddy turbo timer
Nismo Shift knob
Nismo handbrake
HKS Knock-Amp
HKS F-con IS (connected to car radio)
HKS Communication cable ODB
Tomei Racing steering wheel
Lonza Formula horn button
HKB bosskit
R34 GTR battery relocation kit
stuff i have @ home and needs to be build-in :
HKS GTRS turbo (polished+ welded wiggings clamps) with internal wastegate en actuator 0,9bar (rebuild for external wastegate exhaust housing)
HKS Cast exhaust Manifold (rare)
HKS External wastegate 40mm
HKS AFM delete pipe
HKS RB26 intake pipe
Fresh powdercoated front subframe, tension rod brackets and more.
Kleppendeksels aangepast met custom triple flow baffle plates + AN10 fittings welded on the back
Solid steering bush rvs
Veilside rear spoiler (rare)
Nismo Powersteering bushes
ordered and on it's way :
HKS Type-R oil relocation kit
future parts:
Craft Square Carbon mirrors
Complete Nismo ophanging, lower front en rear control arms, tension rods enz....
RIPS Racing intake manifold or custom
HKS Fuel rail
Deathworks injectors
Tomei pomcams of HKS cams
Mishimoto dual fan shroud + fans + fan controller
enz enz enz enz ...............
Engine :
Apexi filter
Greddy RZ blow off
QSP tubing
Nismo gearbox mount
N1 waterpump
HKS timing belt
HKS oil filter
Splitfire coilpacks
Iritop 7 sparkplugs
Tomei FPR type-S
suspension :
Tomei hicas lock 2
Cusco rear strutbar
Cusco brake stopper
Exterieur :
Veilside voorbumper
Top Secret fuel cap
OEM winddeflectors
interieur :
Greddy turbo timer
Nismo Shift knob
Nismo handbrake
HKS Knock-Amp
HKB bosskit
HKS AFM delete pipe
future parts:
HKS Fuel rail
