Peter de Beus R32GTR V-spec Time attack car
  • Peter de Beus R32GTR V-spec Time attack car
    I am Peter de Beus from the Netherlands and owner of a R32GTR-Vspec skyline.
    Hope you will like the car, will come over to germany for some events next year!
    R32 gtr V-spec
    2010 specs:
    Engine:
    Rb26 Early block (87mm) 2.7liter
    Wossner pocketed forged pistons 8.2-1CR
    Wossner forged steel con rods ARP bouten
    ACL race serie's bearings
    cranckshaft ballanced and polished
    Nissan N1 oil pump (word Nitto)
    1.4mm Tomei MLS head gasked
    1.2mm oil restrictor naar cilinderkop
    Tomei competition sump baffle kit
    extendid sump 8.5liter
    external head oil return
    Tomei bronze valve guides
    Tomei Valve retainers and folowers
    Headwork done
    Tomei B type valve springs 10.85mm
    Tomei Procam 272graden 10.25mm lift
    Turbo:
    AET T78-33D Single Turbo with trust 48mm external wastegate
    Apexi 145mm super drag intercooler
    Greddy Type R Dump valve
    Custom PI intercooler Piping
    Fuel system:
    Tomei 280 litre per hour in tank lift pump
    Autosaurus surge tank 5liter
    Paxton aeromotive 900BHP fuel pump
    Sard Fuel Pressure Regulator
    HKS Fuel rail, twin fed 11mm
    Injector dynamics 1000cc injectors
    Engine control:
    Haltech platinum Pro ECU
    Haltech 33mhz boost control kit
    Exhaust gas temp sensor
    Fuel pressure sensor
    Inovate Air fuell ratio meter
    HKS DLI Twin Power ignition amplifier
    FET Power ignition Coils
    Drivetrain:
    C's quickshift
    OS Giken twin plate clutch
    Autosaurus 1 piece lightweight propshaft
    V-spec diff
    Cooling:
    Electric fan conversion
    Greddy alloi radiator hose
    Koyo radiator
    Trust oil cooler & filter relocation
    Exhaust:
    Custom trust/greddy manifold
    3.5inch Trust downpipe
    4inch Invo freeflow exhaust system
    Handling...
    Bridgestone NPG Coilovers
    Cusco sway bars front & rear
    Rose jointed drop links
    Cusco front tie bars
    Cusco front chassis brace
    KTS adjustable front top arms
    HKS Kansai front strut brace
    Cusco rear strut brace
    Do Luck centre brace
    Driftworks & Super Pro poly bushes
    D-max rear tie arms
    D-max adjustable rear arms
    Driftworks full Hicas elliminator
    KTS C pillar brace
    KTS boot floor brace
    KTS 7 point roll cage
    Skylab 4WD Torque split controller
    Brakes..
    D2 8 pot calipers on 330mm discs front
    Ferodo DS2500 pads all round
    3g slotted rear discs
    exterior:
    N1 rear wheel spats
    Japsalon Z lightweight GRP bonnet
    Carbon fibre bootlid
    3D Rear spoiler
    Garage Defend carbon cooling panel
    5Zigen Pro Racer GN wheels
    5Zigen lightweight Log nuts
    Falken azenis semislicks 265/35 R18.
    Sparco Fia bucketseat
    KTS 4 point drivers harness, Luke 3 point passenger harness
    Front splitter
    Engine Rebuild:
    Time attack:
    Hi and welcome here.
    This is a very nice one. Great job mate, always good run.
      Hello Peter,
      welcome to our community and enjoy all the crazy guys here.
      Your R32 GT-R V-Spec looks very very nice. How much horsepower do you think it has?
      To which event you want to come 2011? Where do you come from exactly from the netherlands?
      p.s. Sorry Jungs für mein brachial schlechtes Englisch....
        Hartelijk willkommen bij ons Peter, een lekker R32 heb je!
          Ja heelemal lekker R32 hoor. Die leukt mij wal heel goed.
          van mij ook een hartelijk welkomen op dit board.
          わたくしはばっかです
            I am comming from Veenendaal near Utrecht, (middle of the country)....
            well just have to see what nice events there are in germany
            car has aroud 700PS but not using them all with the time attack, its just useless.... its running 1.7 bar on 98 oct fuell
              what a beauty....
                Little movie, it was smoking a bit because i was using an old turbo (td07S)
                http://www.youtube.com/watch?v=sAZAhPyWXDE
                  Hallo en welkom op het forum!
                  Real is een zeer mooie auto! Ik hou van de R32 GTR!
                    nice ride :)
                    hope to see it on "reisbrennen" at the race track oschersleben.
                    in the video i saw that there are cars with less performance on the track. are you running only on trackdays or are you running on time attack events too? and how you do compare against the other cars?
                      I am also doing time attack as you can see on the picture's, the car is doing pretty well.
                      But it was just the first year of time attack with this car so lot of testing,
                      just ypgraded a lot of parts that where not OK and going to try and improve myself next year!
                      but again i have to setup and test al the new parts etc.
                      would like to drive on oschersleben sometime's when is this event??
                        prachtige sound <3
                        わたくしはばっかです
                          Hoi Peter, heel leuk idee en je R32 is echt de brander. Welkom op het forum en veel plezier hier. Ik wens u veel succes met de nieuw geïnstalleerde onderdelen die alles heeft en ga naar de tijden. Altijd een goede manier:) Leuke video, is het uitgegroeid.
                            Hi and welcome! R32 GTRs RULE!!
                            Great car!!
                            ...und wenn du in dieser Werkstatt nicht das richtige Werkzeug findest, Mister Arizona,
                            dann hast du von Autos keine Ahnung
                              reisbrennen is in the end of august, but i don't know when it exactly is next year.
