Tranq's
  • Tranq's
    war am anfang ein Hobby, wurde im letzten Jahr, mehr ....
    Nissan Skyline BNR 34 V-spec UK No.35 – 2001, 27k miles, daily driver
    Engine
    HKS Intercooler Pipe Kit
    HKS Intercooler fit
    HKS Intercooler BNR34
    HKS Sports DeCat Pipe
    HKS Hyper & Race Cat.
    HKS Hyper Muffler exhaust system
    HKS racing plugs BNR34
    Tomei Cams
    Exedy twin – plate Clutch Kit
    Management
    Greddy Profec B spec 2
    Greddy E- manage Ultimate ECU
    Greddy BNR34 E-manage harness
    Suspension
    Tein Super Street suspension kit with Top mounts
    Cusco Front and Rear top links
    Nismo LM GT3 Alloys 9x18 with Toyo 265/35/18 T1R
    Volk TE37 10.5x 19 with Michelin SP2 295/30/19
    1995 BCNR33 / Skyline GTR V-spec. 24k miles, time attack project
    EXTERIOR/body
    Nismo clear front indicators
    Nismo clear side repeaters
    Nismocarbon style B-pillars
    Nismo Carbon style spoiler endcaps
    Nismo rear spats
    INTERIOR
    real carbon dash set
    Trust/GReddy60mm ,2 x Exhaust temp (EGT), 1 xboost, 1 x oil temp.
    Trust gearknob.
    White instruments(done here by theoriginal supplier to Middlehurst)
    Momo 360mm steering wheel,
    Nismo steering boss
    GReddy Profec B boostcontrol
    GReddy Profec remote switch
    Tein EDFC control unit in centre console box
    Alpine cd/radio head unit
    SUSPENSION
    Tein 'Flex' coil over system with 'edfc' motorised adjusters.
    BRAKES
    Front ; Alcon 6-piston front caliper set / 350mm discs/separate bells, Pagid
    pads,
    Rear ; Alcon 4-piston caliper set, 280mm discs.separate handbrakebells, Pagid pads. (Brakes installed less than 5000 miles ago)
    WHEELS
    Nismo 10x18 'LMGT1' all round with Toyo 275/35x18 tyres
    EXHAUST
    Mines super outlet 'pro' stainless exhaust outlets
    Trust downpipes
    stainless de-cat
    Trust BL TiR full Titanium cat back exhaust (exhaust fitted 2000 miles ago)
    TRANSMISSION
    OS Giken type A close ratio gear set
    OS Giken high strength input shaft
    OS Giken triple plate clutch (withflywheel)
    FUEL SYSTEM
    Nismo in tank fuel pump
    GReddy 11.0mm fuel rail and braided hoses,
    Nismo adjustable regulator
    HKS 1000cc injector set
    MANAGEMENT
    Apexi Power FC
    ENGINE
    Trust 3-row Rspl Intercooler
    GReddy polished intercooler hard pipe kit
    GReddy 16-row thermo oil cooler kit with remote filter mount and #12 braided lines
    GReddy high capacity aluminium radiator
    GReddy GTR blow off valve kit
    ARC oil catch tank
    GReddy rad cap
    GReddy oil cap to engine and catch tank
    GReddy strut brace
    'GTR' stainless fuse box cover
    GReddy radiator air diversion plate
    GReddy racing suction pipe set with induction kit
    Nismo airflow meters
    ATi Racing crank/harmonic damper
    Split Fire coil packs,GReddy iridium tune -8 spark plugs
    Mines camshaft baffle set
    Trust enlarged oilpan (sump kit)
    Trust enlarged capacity front diff cover
    Trust/GReddy T517z/8cm twin turbos mounted on massaged stock manifolds Engine block
    bored +0.5mm (ie 87)
    GReddy forged Piston set(later style with 1mm compression rings)
    GReddy H section connecting rod set
    Nismo oil pump
    GReddy crankshaft main stud set
    GReddy cylinder head stud kit
    stock Nissan crank on stock journal diameters
    full dynamic balance to reciprocating assembly
    Tomei engine block oil restrictor
    Nismo connecting rod bearing set
    Nissan crank bearing set
    GReddy 264x10.0mm intake camshaft
    GReddy 272x9.1mm exhaust camshaft
    GReddy valve springs
    Tomei valve guides
    GReddy adjustable cam sprockets in/ex
    GReddy high strength cambelt
    GReddy clear front cam cover
    Light head work /3 angle valve seats
    GReddy 1.4mm steel head gasket
    GReddy steel intake and throttle gaskets
    R34 GTT Skyline, drift project
    Front pipe
    DeCat
    Kakimoto Racing exhaust system
    HKS Front mount intercooler
    Apex'i Air Filter kit
    Nismo Rad cap
    Nismo Gauges
    Apex'i Turbo Timer
    Tein Super Drift coilovers
    HiCass delete kit
    Gizzmo boost controler
    Apexi Power FC
    Driftworks R34 GTT Suspension Arm Kit
    Ja dann mal ein Herzliches Willkommen hier und allzeit Knitterfreifahrt mit deinem Fuhrpark....
    hast dir ja ordentlich was zugelegt....
    greetz Dome
      Willkommen bei uns... Schön das es nun mit deinem Passwort geklappt hat ;-)
        willkommen ^^
        so viele specs hab ich auch noch nich in ner vorstellung gelesen ^^
          Das liegt wohl daran, dass hier jeder nur n Muffler und n Sportluffi verbaut ;)
          Sehr schönen Fuhrpark hast du dir da zugelegt.
          Besonders der BCNR33 gefällt mir. :)
            Der BNR34 ist einfach nur der Oberhammer...wobei die anderen beiden Schätzchen ja auch nicht ohne sind...SEHR SCHÖN....weiter so
              dann sag ich auch mal hallo!
              sehr sehr seeeehr netten fuhrpark hast du da! könnte man(n) klatt neidisch werden :D
              !!! fun is starting @ 4700 RPM !!!
                Hi, dank an alle.
                Nochmalls danke fuer die Freischaltung, Uwe.
                Ist im moment noch leicht hier mit den upgrades, der TUV ist nicht so streng.
                Ich hoffe der Schnee bleibt nicht zu lange, es sind ein paar Teile zum einbauen schon da...
                Ich bin vom 19-23.05, am Ring falls jemand in der nehe wohnt gebe ich gerne eine aus.
                Zuletzt geändert von Tranq; 10.02.2010, 20:06.
                  Wow nije lose nebih mislio da ce se takvo auto ovdje pojavit sa hrvatskim tablicama *thumbsup*
                  Kein Schw**z ist so hart wie das Leben =)
                    hallo und herzlich willkommen. na da hast du aber schon tüchtig gesammelt in sachen skyline-sammlung. stehen noch weitere anschaffungen auf der liste? und was haben deine drei schätzchen denn so ca. an leistung? :-D
                      Moin Moin und willkommen! Wow da hast Dir eine nette Skyline-Flotte zugelegt, Respekt!! Aus welcher Ecke kommst Du denn, oder hab ich das überlesen?
                        Ja, ein R32 mochte ich auf jeden fall noch haben. Ob es in ein paar Jahren dan fur ein Hakosuka und Kenmeri reicht weiss ich noch nicht
                        Der R34 ist im moment bei 450 hp
                        Der R33 zeigte 595 hp am dyno
                        R34 ist noch nicht gemapt, sollte zwischen 320 und 330 sein.
                        Ich lebe in Zagreb.Lebte aber fruher in Reutlingen.
                          nicht schlecht... laufen bei Euch sonst noch andere Skylines?
                            Nein.
                              dann bist du ja bei dir in der ecke, der absolute eyecatcher schlechthin
